Clear a Dynamic SBT Entry
Use this procedure to clear all or a particular dynamic SBT entry.
  1. Enter Privileged EXEC mode:
    enable
  2. Clear a dynamic SBT entry:
    clear ipv6 fhs snooping [vlan <1-4059>][ipv6-address WORD<0-46>]
Clear a dynamic SBT entry on a VLAN.
Switch:1> enable
Switch:1>clear ipv6 fhs snooping vlan 1000 ipv6-address 2001:DB8:89ab:cdef:0123:4567:89ab:cdef
The following table defines parameters for the clear ipv6 fhs snooping command.
Variable
Value
Specifies the IPv6 address for the binding entry to clear. You cannot specify an address without first specifying the VLAN.
vlan <1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
If you do not specify a VLAN, the command clears all entries.
